Update (and needing some input from Dave / Gord / others):
Ok, so now the Z is on the Megan /McKinney coilovers, with the adjustable LCA's and adjustable tension rods. Not slammed, still 1.5" between tire and fender lip.
A couple issues:
1) coilover "clunk" - All I can say is, GRRR. I realize they're going to be noisier than stock suspension, but the clunk when turning the wheel at low speeds is annoying. Any ideas?
2) Adjustable tension rods - The bracket for the heim joint interface with the tension rod mount on the chassis is a PITA. I know the bracket is supposed to remain "flat", as in, keeping the rod through the heim joint perpendicular to the ground, but mine wants to turn (when I tighten the control arm bolts behind the frame mount. Ideas?
3) Harshness - OK, this one's my fault, for going with ALL poly bushings for the entire suspension. My question is, if you wanted to change ONE set of bushings that would make the most difference in reducing ride harshness, which would it be? She's amazing on smooth surfaces, and the damping for large oscillations is great - but it's the small road imperfections that are the most jarring. Something that crossed my mind, but I wanted to ask the pros, CAN I use a small rubber bushing where it goes through the chassis mount? Thoughts?
4) Alignment settings - Dave gave me some good settings before, but I was talking with some of the local Z guys who said that keeping the rears as "straight" as possible (zero camber) while dialing in 2 degrees in the front, would give it a nicer feel for street use (considering the power the RB is making). Thoughts?
5) "Vibration" on hard acceleration - R200LSD, original axles (U-joint style), new driveshaft, poly mustache bar bushings and diff bushings. Feels almost like the axles might be "binding" a little or have some roughness when I give it heavy throttle and the rear squats. I have a CV axle conversion here (not yet installed) - Think that might resolve this issue, or is there something else I should look at?
Thanks in advance, guys - Trying to get her ready for MSA Nats next weekend, would like to address as much of this as I can before then.
Pics of the LCA's and TC rods:
