Paddle shifter?
All things Altima Coupe.
Odderthan
Car: 08 black altima coupe 3.5 SE fully loaded, every option, except factory spoiler.
I know it really wouldn't make sense with a cvt trans but technically since we have the "manual" mode could you just wire it up with a 350/370 steering wheel? I'm putting a cut out on my car since i eant louds but not all the time for a daily driver and just want it for the occasional pulls.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
This will give you an idea of what's entailed in adding paddle shifters.
philipa_240sx wrote:Welcome to the NICOClub Rogue Forums Cdj!
All Rogue models actually have the same CVT automatic transmission.
The difference you are referring to is the manual/paddle shifter available on some 2008-2009 SL models. All this does is select a fixed gear ratio through software... to mimic a 'Tiptronic' or manually shifted automatic transmission. This does not affect the reliability, if anything the manual shifted models are desirable as they also include a transmission oil cooler which can be beneficial if you drive in a hot climate or tow a trailer.
Good luck on your purchase!
HowTo: Install Paddle Shifters - M37/M56/Q70
M56 - Paddle Shifter Upgrade
Paddle shifters worth it?
