DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Jul 21, 2003 11:21 am
What makes them work is a thin wire filament near the tip. Painting the tip will not help, unless the paint is extremely conductive (silver-filled epoxy paint maybe). I once repaired one by soldering a wire across the broken ends. It's about impossible to get *just* right though, since the height of the sensor is critical. If you screw it up, it'll go off to early or too late. Better off just splicing the wires to make it easier, or just keep using factory pads.
