JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Fri Aug 17, 2007 4:18 pm
Ok, so maybe im being a little harsh. I have had my pacesetter header for the last 9 years. But driving home from work, in the 97 degree south Louisiana heat, my car started missing. I figured it was because of the high compression pistons, the aggressive ECU tune, and the heat. Then it started missing BAD. Like i really thought i threw a rod through the side of the block bad. Limp the last 2 blocks to the apartment, park it and pop the hood. I have a dime sized hole on the #4 exhaust tube and a pea sized hole on the EGR outlet of the header. Damn mild steel piece of garbage. I knew i shoulda spent the extra dough waaaay back then and gotten the Hotshot. O well, looks like i'll be trying to find an OBX single cam header now.
Im actually glad this header lasted as long as it did. Nine years is a long time to be beaten on, especially for what was, at the time, the cheapest header available. But it does suck that it blew out and i now have to spend money replacing it. Oh well, thats life.
I did go to Advanced Auto Parts and pick up a "exhaust system repair kit" that consists of some goop, a aluminum sheet covered layer of fiberglass, and some metal band clamps. Didnt work worth a squat. O well, it was only $4 and change, worth a try at least.
