Pacesetter header, $80.. worth getting?
0range_240
Car: 89 HCR32
Hey all, I know what you all think of pacesetters.. but I found a cheap *** header thats was blasted and re-painted with high-temp engine enamel. So all rusting problems have been addressed, is there anything else I should watch out for?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Unless it cracks there shouldnt be any problems. I hear they dont fit too well though.
whiterps13
Car: white LE hatch
mine came on the car when i bought it, and at idle sometimes it rattles against the floorboard.
0range_240
Car: 89 HCR32
What kind of power gains should I expect?
240SXedUp
Dont waste your time/money. The only way id waste my time installing them is if they were for free
0range_240
Car: 89 HCR32
thats not what I asked... I want to know perf. gains... thats all... nothing more... Ive read ALLLL the posts about how they rust etc... Ive got mig welders, arc welders, and a 2400 sq. foot, 4-car garage with a lift if something breaks.. so I dont really care if they need to be welded again or whatever... I just want to know about the performance gains, if there are any
Chingon
Car: 1991 and 1992 hatchbacks
so why don't you fab one instead? You did ask if it was worth getting...
0range_240
Car: 89 HCR32
aight thats true my bad... but I dont think im up to the task of fabricating one... I dont have a mandrel bender, or even a press-bender for that matter. I just want to know if they show any perf. gains
0range_240
Car: 89 HCR32
*bump*
JJ240
Car: 95 white 240
Of course there will be some performance gains. Its impossible to tell you how much because that depends on your engine, and what other mods you have done. If you dont have anything else done to your engine I would guess you might gain 3-5 rwhp. If you already have exhaust and intake you may see more like 5-8. But thats all ballpark guess.
GEO
Car: 95 240sx KA-T
just go hotshot..
0range_240
Car: 89 HCR32
I appreciate the info JJ, and vengeance: Ive looked at hot shot aswell, and done my fair share of research. The reason im more interested in the pacesetter is the 4-1 design, which would benefit my top end, whereas the Tri-Y design on the hotshot would give me gains more noticeable in my midrange... and seeing as I have a SOHC, top end power is where I need power most.
Btw, JJ I have intake, exhaust, and pulleys. And my motor is still running strong with 165psi across all 4-cyl.
240SXedUp
I dont believe in lowballing it just to get a couple hp. You can get a hs header for 300 and you will get 12hp 10ft/lb (dynoed figures).
0range_240
Car: 89 HCR32
Im not "lowballing it", did you even read my last post? I said I wanted a 4-1 type of design, not a 4-2-1... every man and his dog knows how great hotshots are, and the dyno figures? its been talked about, over a million times on these forums. I'm sorry but what you said was not only insulting to my intelligence, but had literally nothing to do with what I asked....
I dont criticize anyone else for buying a certain brand of part for their car. And I would expect other people would be mature enough to show the same courtesy.
Onizuka
Id say for $80 you've got nothing to lose but some blood and sweat putting it in (experience is good right? :D ). Let us know how it works out :)
0range_240
Car: 89 HCR32
Thanks J-spec.. I appreciate the quick reply =D
JJ240
Car: 95 white 240
Ive got a set of custom headers designed like the pacesetters only with slightly bigger piping, and my friend has hotshots. The hotshots have bigger runners than the pacesetter Im 90% positive. And I think his hotshots give him better topend than my 4-1s. They are really well designed headers and if its not the cost that is deterring you I would suggest you get hotshots.
0range_240
Car: 89 HCR32
How did you make your header? Im really interested in this
JJ240
Car: 95 white 240
Its just flange ordered from online, and mandrel bent runners that meet at a collector bought online.
0range_240
Car: 89 HCR32
What kind of gains did you get out of it? and how much did it cost ya?
JJ240
Car: 95 white 240
Gains, not sure because Im still running stock exhaust. An exhaust flange is around 50 dollars, 4-1 collectors are around 10 dollars, then just have to find someone who can do the piping for you, I have no idea how much that would cost.
DeathBy240SX
I'd say go for it. Where are you getting the headers so cheap?
0range_240
Car: 89 HCR32
Guy emailed me with them for sale a while ago after I had put up a wanted on NICO and zilvia for a header. Took him a while to get pictures thats all. All together its coming to $105 US inc shipping
karay240
I understand that you're wanting the 4-1 headers b/c of the lack of top end on the sohc (the KA24 for that matter). Do you think that the sohc motor will rev high enough to be in the efficiency range of a 4-1? I doubt that even the dohc would. I'd wouldn't worry about getting a 4-1 unless I got a honda. Getting a 4-1 on a KA w/ only bolt-ons will only kill the low-end while only marginally give top-end power gains (probably about as much as the 4-2-1)
