dnasty88 wrote:for the life of me i cannot find the installation instructions for the pac swi jack. i wanna forward them to my brother who will be doing my install to make sure he can do it, but i can find them. if someone could give me a hand that would be appreciated ...and a few more questions
doc you said in my previous post that i need to only purchase the oem double din dash piece and use the factory brackets to install my navigation system. im going to go with the kenwood 5120. is this all i need?
is there a write up to install the 5120? i know in the d3 write up it has you wire some pink wire to a vss sensor wire behind the gauge cluster..what is the point of this and will this be a step in the 5120 installation?
ok, let's start one at a time
1. the pac swi jack installation diagram is
http://i241.photobucket.com/al...k.jpg
2. the installation instructions are
http://www.pac-audio.com/swixp...D=112
3. I believe I stated that your factory brackets should fit the OEM piece... when I did the install, I used the metra kit, but if its an OEM piece, the OEM brackets should be used. The only things is I don't know if the OEM brackets for the cd player/bose cd player are the same as the brackets for the navigation unit, but again, I would imagine that either bracket set would fit. If you have the factory brackets for the regular stereo, I would spend the $20 to purchase the navigation brackets just in case... it may prove to be useless, but it may save you time in the long run
4. there is no ned to do a write up for the 5120, the general instructions will apply..
5. there is no pink wire on the kenwood units, the kenwood units don't use the VSS wire, so you don't have to take apart the speedometer/odometer and hook anything up there (lucky you the vss is the vehicle speed sensor, it helps the pioneer units track exactly how fast you are going. The kenwood units use the garmin GPS system which is MUCH better than pioneer's, so the kenwood units don't require this.
6. to watch videos while the car is in motion, just attach the light green wire leaving the kenwood unit to another gorunded wire, or to somewhere on the metal chassis of the car
7. WATCH YOUR BROTHER DO THIS INSTALL!!!!!!!!!!!
Hope this helps6.
