The "dips" that iron gym give you are useless- there's not enough resistance to force your muscles to work, and the range of motion is minimal. You're better off doing them with a coffee table and a chair, with some weight in your lap.
Anyhow, these are copy and pasted responses (from myself) from mmm240's thread "My first time taking supplements.
SHIFT_Z wrote:Ok, well my background is I have been heavy lifting on and off for 3 years, so I'm not pulling much, if any, of what I say out of my ***. Have done a lot of reading, and a lot of talking to others / made phone calls about stuff. Anyways, here I go:
If you're taking a PRE-WORKOUT supplement, i.e. an energy booster (NO Xplode is what I've used for years), NO VAPOR, etc... You need to see how much caffeine it has in it. It probably won't say it straight up on the container, so you have to look for what chemical it is named for, or look it up on the internet.Chances are it won't have a TON, but it's enough that if you have caffeine in your diet already, such as drinking sodas, or drinking coffee... you need to cut all of that from your diet, or start consuming caffeine-free alternatives. All that caffeine is terrible for your system.
Precursor: Taking fast-absorbing protein (such as whey) is just as important BEFORE your workout, as it its after. More on that in a bit.
You need to drink a protein shake about an hour and a half to 2 hours before your workout (if you are energy-boost supplement- Heres why:It might not be the same for others as it is for NO Xplode, but the principals are the same. Take the protein shake at LEAST an hour prior to your workout so it can fully digest... then take your cocktail about 30-45 mins prior to your workout to give it time to get into your system. On that note; the stuff usually works best on an empty stomach, so it can go straight into your bloodstream and to your muscles. If you have a ton of food in your stomach, it won't be as effective. READ THE CONTAINER though, to make sure.
Post workout:Again, Whey is the best since it gets to your muscles fastest. However, taking 50g of whey after a workout is a waste. The human body, per setting, can absorb anywhere between 20-30g of protein, the rest gets pooped out before your body can use it. So if you are using whey, take a single serving immediately after you're done working out, and take another a few hours later. Otherwise, you'll be paying $$ for something not getting used. If you are going to protein stack, take something like a casein protein, or a whey/egg/casein blend. it takes up to 3x as long for your stomach to digest... Meaning its feeding a constant stream of protein to your system. Shakes made with this kind of protein are best in the morning, and before bed. Again, Whey is best for before and after training.
GNC guy is right; if you're trying to build, 1 to 1.5 of protein per lb of body weight is correct, but you'll find that this can be difficult to do. Thats why you supplement the protein IN ADDITION to your meals. Don't supplement the protein in-place of your meals, as it doesn't contain the proper nutrients for your body to live off of.
A good lifting-oriented multi-vitamin is essential if you are trying to get in shape. When you're more active, your body needs more nutrients, and so do your muscles. You might be starving your body of the supplies they need if you're not taking one. Check into Optimum-Nutrition's Opti-men vitamin, it's a good one.
Be drinking at least a gallon of water per day, as well. Especially if your pre-workout booster has creatine in it. Your body will get nowhere fast if it's dehydrated, and also since most whey-proteins these days are instantiated... meaning they absorb quickly into water, making it easy for your body to break down and use.
As far as your lifting routiens go, try and get a spotter, or a buddy to start lifting with you. You'll quickly realize that you have so much better of a workout when you have someone there. For one, they will be there if something goes wrong and you get injured.. or to prevent the injury in the first place. ALSO, it's a mental thing. Whether you realize it or not, you'll be competing with the person... giving you a more efficient workout.
Hope this helps!
mmm240 wrote:That was excellent! Thank you.I only drink water, and um, booze. So I'm not too worried about to much caffeine. And I drink a LOT of water; gotta make up for the dehydration the booze causes.I didn't know that I should take a protein shake before my workout though; will do. I'm not very active though. I know that I should be eating more meals and less at each meal, but because I'm not very active. My hunger limits me to say two 8oz meals a day; maybe three. Have any thought about this?
I work out in my basement and there's really only room for one person to be there at once; bench is in my laundry room. I'm careful though; I know my limits.
SHIFT_Z wrote:Take what you would normally eat, and split it in half, and eat 4 smaller meals a day, with a shake before / after your workout, and another as a snack at some point during your day. doing this will also keep your metabolism going nonstop. That extra shake you need is great for breakfast, because when you wake in the morning your body is starved for amino acids, thats a great way to deliver them and get your metabolism jump started.Since you are increasing your calorie intake, it would be wise to include some cardio in your routine, as you might gain some weight depending on your metabolism.
Also, do LEGS! I know a ton of people that say they never do leg workouts, and they also end up looking weird, being a upper-heavy person on these frail-looking stick legs. Waaa! Legs are important. Do something for your quads, calfs, hamstrings, and butt, at a minimum! Running is great too.
With the alcohol, yeah I drink sometimes too- but keep in mind that when you flood your body with alcohol (more than it's used to breaking down) , it can reduce muscle synthesis by up to 30%. Plus, 1 shot of liquor has the same calories as a beer, sometimes more. Light beer has around 90 calories... so if you figure to get a buzz that you drink 6 beers... thats 540 extra calories on top of what you ate that day.. So be careful!
I would also strongly recommend getting a good fish oil to supplement in as well. Take it 2-3 times a day with meals. It's great for your heart and circulation, and gets you the omega 3's that your body needs.
mmm240 wrote:I do legs; they are my cardio workout. I don't know the terms, but I use that part that's connected to the end of the bench.My body is used to breaking down alcohol.
I will look into some fish oil. Thanks again!
