forumoto »
https://forums.nicoclub.com/forumoto-u189765.html
Wed Aug 08, 2012 1:31 pm
thank you morgan, for keeping up with my issue, well i have changed the ecm, and done all wiring probe test and all prove right, the only thing that i did not get is, test pin 1 and 4 on the ecm,, with pin 1 that is blue, key turn onshift liver shifted to D, and now grounded negative to battery and using positive tip to check terminal 1, while acc padel is pressed down, but i do not get no reading from it and when i checked pink terminal on 4, and released pedal, there is no reading on the digital meter,
