abrusnahan »
https://forums.nicoclub.com/abrusnahan-u310694.html
Sat Aug 26, 2023 6:14 pm
Hey,
I have a 2012 Nissan Quest that threw a P1778 code. It was slow to start and a little jumpy upon acceleration. I went ahead and ordered the part on eBay and attempted to do the job myself. I dropped the pan and I think our setups our similar with the exception that my stepper is completely visible right when you drop the pan. It's sitting next to the filter. Well I took the filter off and the two screws holding in the stepper, and I let the ratio control arm spring back to it's starting position. Was that a mistake?
I installed the replacement stepper and hooked the actuator arm from the ratio control valve back into the stepper arm. I reinstalled the filter and the pan and replaced the lost fluid (with new fluid). Upon starting the vehicle, I cycled the gears to distribute the fluid evenly and everything was cycling fine, but when I removed my foot from the brake to actually engage the reverse, the van didn't move. I tried to engage the Drive and Low gear and got the same result—no movement.
I figured that the ratio control arm became unhooked from the stepper so I dropped the pan again and checked everything out. Everything seemed correctly installed so I reinstalled everything. Still got nothing when I put it into gear. I dropped the pan a 3rd time, this time deciding that I would just put the old stepper on since this one seemed to be a dud. I at least was able to move with the old stepper. However, when I got everything reinstalled, I got the same response—no movement.
Clearly, I've done something wrong, but I cannot figure out what it is. I checked the codes again and it's still showing a P1778 code. My gut feeling says it has something to do with the ratio control arm and the fact that I let it spring back to it's starting position but a guy on another forum said that shouldn't be a problem.
Can anyone help me with this? Any help would be tremendously appreciated as this is our family vehicle.
