,Low Speed Fan CTRL relay circuit
, both had this description circuit issues are usually caused by loose connectors or faulty wiring. then for few days now i had trouble starting the vehicle, I discover a way around issue but its not reliable. Battery is new, bought this year, I do have corroded battery cables(-)needs replace, (+)recommended replace. The trick i found is when turning key to start, I do a double click/turn method. Like start your car twice. My question, are the codes and starting issue related because the light does go off for a period then on again, 2nd time within year. Had issue earlier thats when i replace battery and saw cables need replace. everything was good then lights comes back on after a couple of months.Vacuum Cut Valve Bypass Valve
Any suggestions, knows a fix, or where to begin to diagnose? I been searching the forum for related topics but nothing similar to this extent. thanks
