480sx »
https://forums.nicoclub.com/480sx-u50548.html
Wed Mar 28, 2007 1:31 pm
The FSM doesnt have this specific code in it but give me a little more info. What exactly does the code read when you scan it? There are two Evap canister valves. One is Evap canister purge control valve, its a little black circular thing with 2 big vacuum lines running off of it, and one small one on the top. Its near your throttle body, you cant miss it. The other is Evap canister purge control solenoid valve, its underneath the runners of the intake manifold. (if its this i have a perfectly functional one that i just took off my car if you want it..)
It sounds like it would be the first one though, the canister purge control valve. To test it, all you gotta do is blow air in each one of the 3 ports. Use your lungs to do this, not an airchuck. If it leaks at all, replace it.
If it doesnt leak well, i feel bad for you because you probably have to take off the intake manifold, im not sure if you can take off that solenoid with it on.(if you can, its STILL a pita im sure)
Done and done, hope this helps.
