m0nkeyprince wrote:well, i thought it was a leak in the lines as any loss vacuum when the ecu tests it would have triggered the code. Just in case, i cleaned the cap threads and the filler hole and reset the code with my scanner. The code never popped upped again. I recommend you do the same before spending money on the gas cap
32.51 after taxes. i gues its alright, onlines its like 12.99 + shipping and didnt have that stringy thingy that keeps the lid from rolling under your car and into a storm drain never to be seen again leaving you standing there at the pump with your thumb up your bum screaming FUUUUUUUUUU : )m0nkeyprince wrote:ah yes, that sound of escaping pressure everytime i go to fill up. Well, least it wasnt a more expensive problem right? how much was the gas cap?
