I exhausted the checks on the EGRC solenoid valve circuit finding all wiring in tact and the solenoid valve of proper value around 30 to 35 ohms. I had to go to a Nissan dealer and measure the resistance of one off the shelf at the counter since I could not find it elsewhere. I was hoping that it would be significantly different from the 34 ohms of the one on my car. Not so!
Now, having exhausted the solenoid valve circuit itself, the only remaining prospects seem to be either the output stage of the ECM is not taking the EGRC solenoid coil to ground to turn it on, the proper input variables to the ECM not present, or the manner/logic/program in which the ECM produces an output is not taking place.
Having described this situation to the Nissan dealer technician, he related a virtually identical scenario and indicated that when they run into this, they have used complex scanning tools than the simple code reader and do a rather extensive procedure which I could only do with the equipment which I don’t have to do it. He deduced that it was either an ECM problem or some peculiar input issue.
If anyone has any advice on how to narrow this down any more, I have basically done the Factory Service Manual procedure which did not get into ECM or input issues at all.
The ECM sees the output circuit and I know it since I get a P1400 pending if I disconnect the EGRC solenoid valve without even running the engine and then do a READ. The ECM knows that the circuit is open circuited but it may not know if its own output transistor is not switching when told to do so which grounds the EGRC solenoid valve turning it on and shifting its valve spool when the other right inputs are received.
No advice here will be taken lightly! It’s either new ideas to try or off to the dealer. GEEZ! I hate when that happens. It seems like the cowardly way out but I just don’t have the gadgetry to get much further. I’d love to see the circuits for the ECM if they even exist. I do have the pinout information on the ECM but I can’t tell what inputs actually have anything to do with the EGRC solenoid valve being taken to ground other than general ideas from this article similar to my problem which begins on page 3...”CASE STUDY”
http://www.vcertt.org/news/11-02.pdf
