P1336- crank sensor replaced, and vibration continues
_evilive_
Car: 1999 Infiniti QX4
Hi all, my 1999 QX4 has a engine vibration and the check engine light was on, a code P1336 was shown- it says "crank position sensor" malfunctions. Last weekend it was replaced, and the engine runs smoothly for only one night. however next morning the P1336 comes back.
I would like to know if any one meets this before? Or some expert might be able to talk about it?
Thank you!
timmack
Car: 2002 Nissan Pathfinder SE
maybe the new sensor went faulty?
tmorgan4
Car: 2000 Nissan Pathfinder
Did you replace the sensor yourself, or have a shop do it? If you consider yourself able to do this kind of thing, you should be able to do a procedure to test the sensor. I'll see if I can track it down in the FSM.
