The condenser is a possible cause and the power transistor built into the coils is also a possible cause. I would focus on the new coils first since those aftermarket coils may be suspect. Testing them for this possible transistor issue is simple enough with a multimeter to probe their connector pins for resistance. (see page EC-509 for the FSM
https://www.nicoclub.com/service-manual ... System.pdf ) Open or shorted harness or connector issues is also a possibility, especially since you already discovered rodent damage to another wire. Pages EC-499 through EC-509 covers everything you can check regarding this P1320 ignition signal circuit fault code without having to remove the coils. Additionally, some aftermarket components can have flakey connections to the stock harness connectors if the flat connector pins on the coils, for instance, are made a bit too thin to make a solid contact to their connectors. If that is the case, giving the pins an ever so slight twist, using a needle nose pliers, will better assure a good contact when they are plugged in.
