dflipmode »
https://forums.nicoclub.com/dflipmode-u125224.html
Fri Jan 30, 2009 6:35 pm
The symptoms that i have are the same as a misfire condition. You can feel it at idle, vehicle shakes at around 50mph at steady speed, shakes as well above the 60mph range. I have the code p1320 and a p0300. It doesnt tell me which specific cylinder. I have tried taking the harness off each cylinder while the vehicle is idling to see if there is any changes to the rpm and possibly figure out which cylinder would stay the same at idle even when disconnected, but no luck. I have changed the air filter before to a K&N and it might be possible that the MAF sensor is dirty. But other than that, I have followed every step according to the service manual as to what to check for and still no luck. The only thing that I have found before when I changed the plugs is that #3 plug is white compared to the others, so that is a possibility that it might be a fuel problem? But other than that, I dont have a clue. I refuse to follow what the damn dealer says and just replace all the coils because it is a waste of my money if that is not the problem and if anybody else have any input, that would be great. thanksdennis
