Here is the jist: I have megan test pipes, so I've installed extra non-foulers not to get O2 errors. Few days ago because one of the non-fouler elbows after some time sagged too much down, when getting into a bay for an oil change my left bank O2 sensor (downstream) was smashed right off.
So here is the dilemma, since then of course I've got 6 errors all connected with O2 sensors all around. I have installed correct downstream O2 sensor (Left bank NGK 24404), did ODBII reset and now I have only two but persistent closed loop errors (p1148 and p1168) on both banks.
Questions:
Do we have an O2 sensor fuse? If we do, which one is it? (there are 3 fuse boxes in 2006 M35)
If we do not have O2 sensor fuse, could smashing of one of the O2 sensor have caused all other O2 sensors to fry/mulfunction?
If I do hard ECU reset through peddle dance (clearing through ODBII doesn't work) will it reset and get rid of this issue?
Does rainbow really taste like skittles?
Any wisdom is highly appreciated
