P1147
soccer882005
Car: QX4
HI,
I had P1147 error code about a year ago. I bought two NEW DELPHI 4W OXYGEN SENSORs and replaced the two downstream sensors. It was fine until a month ago.
I wonder if anyone has the same experience. Should I use Bosch parts to replace again?
Thanks,
soccer882005
Car: QX4
Forget to mention two ELPHI 4W OXYGEN SENSORs were bought on Ebay.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Which year QX4?
Bosch is the original manufacturer of the oxygen sensors. However, P1147 is not at all related to the oxygen sensors, why did you replace them?
A possible cause of your P1147 code could be a clogged vacuum hose around the EVAP canister.
soccer882005
Car: QX4
Thanks, I will check the EVAP
