p1145
stanghater
Car: 2002 Infiniti QX4
2002 Subaru Impreza WRX | 474whp
2005 Subaru Legacy GT Wagon | 258whp
I was under the impression that this was the drivers side for this code. So i bought a new sensor(i think) and replaced it. it was short and round and it was on the front of the engine block http://www.oreillyauto.com/site/c/detai ... ion+sensor. Installed it, cleared the ecu and started it up. No CEL. then, after idling a bit, it came back on. I read the code ... p1145! wtf?! so i cleared it again, same thing only this time the CEL is blinking at me. like blink blink blinnnkkkkk blink blink. any ideas?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
The part you ordered does not look like a camshaft position sensor:
You say you replaced something at the front of the engine? Can you provide a picture of where exactly you installed your new part? I had to replace both of my camshaft position sensors and they were not on the front of the engine block. I followed this guide. I bought two of these from Amazon and have not had any issues.
asnorton44
Car: 2001 Infiniti QX4
Yeah you need the part as listed above.
Also you may want to look into replacing both sensors, when mine went the other one went shortly after.
stanghater
Here's what I found when I pulled the correct one out
CEL is gone. Thanks guys
Towncivilian
Yuck. My "bad" sensors didn't look nearly as bad as that. Glad you got it fixed!
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
I agree, yuck. That's a sign that the whole engine looks like that inside. Have a peek through the oil filler cap.
Chuck
WPGQX4
Car: 1998 Qx4
May be time for an engine flush and synthetic oil.
