Tiny correction that 2004 did have the VQ35 still. But what's a P1140/P1145 in a 2004 R50 when those intake valve control timing positions sensors were omitted on drive-by-wire models (03-04)? Guessing African R50s were still drive-by-cable up to 04?VStar650CL wrote: ↑Tue Nov 14, 2023 12:54 pmP1140 is for the passenger side bank (bank1). The driver's bank would throw P1145. Nissan stopped putting the VQ35 into Pathies here in the 'States in '03, but if you look here for an '01/'02 it should get you to the right part number for your screw:
https://www.nissanpartsdeal.com
Yah, I'm assuming his overseas model must be different. The FSM's from '03 up don't reference P1140/P1145 for USDM Pathies.
The P1140 DTC is a Bank 1 (passenger side) fault code. Although there are 2 of these sensors on your engine, the trouble code points to the one at the front, top, right side of the engine. In the following link, there is a diagram showing where it is. Looking at the front of the engine in this diagram, it is the one on the left in the picture. https://www.nissanpartsdeal.com/parts/n ... &filter=()
VStar650CL wrote: ↑Tue Nov 14, 2023 11:37 amUnless there are hydraulic issues with your cam phasers, P1140 with no other codes is almost always a faulty sensor and not a faulty solenoid. Try a new sensor.
The cam position sensors affect the ignition spark timing. If that bank 1 sensor is not accurate, your ignition spark at cylinders 1, 3, and 5 can be firing too soon or too late.
