P1140 Code and Replacement
02pathfinder
Car: 2002 Nissan Pathfinder
Got the P1140 code when going through inspection. Want to change the part and just need a little help clarifying where it is located. Also, any help to the best and easiest way to get to the part to replace it would be greatly appreciated. Is this the correct location and part? Thank you
asnorton44
Car: 2001 Infiniti QX4
Easiest way to get at it is taking out the battery, its towards the front of the engine.
