P1138/P1139 Rear 02 sensor error, is there anyway to test??
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
My car is throwing a P0138 and sometimes along with it a P0139 which is for the rear passenger 02 sensor. Im curious after reading some posts about it if the actual sensor is failing, or if I have a shorted wire. Can anyone give me advice on testint the sensor or its harness connection to check proper operation or if there should be a certain reisitance against its connection terminals??
I found this info on these codes while searching
*P0138 02 sensor circuit high volts (bank 1 sensor 2)
The rear heated oxygen sensor (or sensor 2), after three way catalyst (manifold), monitors the oxygen level in the exhaust gas on each bank.Even if switching characteristics of the heated oxygen sensor 1 are shifted, the air-fuel ratio is controlled to stoichiometric, by the signal from the heated oxygen sensor 2.This sensor is made of ceramic zirconia. The zirconia generates voltage from approximately 1V in richer conditions to 0V in leaner conditions.Under normal conditions the heated oxygen sensor 2 is not used for engine control operation.
*P0139 Heated Oxygen Sensor 2 Circuit Slow Response (Bank 1)
Possible Causes:
- Harness or connectors (The sensor circuit is open or shorted)
- Rear heated oxygen sensor (Bank 1) may be faulty
- Fuel pressure may be faulty
- Injectors may be faulty
- Intake air leaks may be faulty
I'll buy a new sensor if thats what it comes down to, but Id like to rule out wiring and for sure have a faulty sensor before spending the $150
Thanks guys!! :mike
asnorton44
Car: 2001 Infiniti QX4
This may help you:
Front Heated Oxygen Sensor Heater
Resistance [at 77F] 2.3-4.3 ohms
Rear Heated Oxygen Sensor Heater
CanuckQx4
It would probably be very helpful if it was only 20 degrees out right now lol
