They only make a small click, and that ohm range is pretty normal. Sounds like you have a leaky o-ring.wesinatl wrote: ↑Fri Dec 03, 2021 11:05 amPulled the offending bank 2 (drivers) solenoid and it was clean as a whistle. No gunk. Tested voltage from car, good at 12, tested for working solenoid and it made a small sound so i guess it works. Not sure how big a thunk it should make if it works, also tested ohms at 7.8. The other side gave 8.6. Is that a potential issue?
My grandma called it "age-atism". Plastic gets it too. You should see what we go through to keep some old Z's and 240's running, a lot of those connectors are near-impossible to get. One thing that will help is spraying them with WD40 when taking them loose, then applying some di-grease to the contacts and seals before re-insertion. When they stick and break, it's not just the plastic being embrittled, it's also from crud underneath the release pawl and "stiction" in the seals. Cleaning and lubrication will make them last longer and reduce the chances of breakage. Fortunately, the IVT connector shells on your ride should be pretty easy to find in a JY, in better shape from a later model. Unpinning them isn't difficult, it's similar to the way it's done here. You'll just need a set of fine picks:
You won't see any low pressure on a gauge when an o-ring pops. The things that are being pressure-deprived by the popped ring are all in or under the front cover; solenoids, phasers, tensioners. Pressure gets measured at the pump outlet just past the filter, and the loss of pressure there will be minimal. When the oil reaches the front cover, the popped ring is simply letting it shoot out sideways into the cover and pan instead of going where it needs to go. The only danger aside from codes is if the bad ring completely disintegrates, then the tensioners can suffer complete pressure loss and allow the timing chains to jump.Soliyou wrote: ↑Sun Dec 05, 2021 3:21 amI am having a similar situation with my 01 qx4. A p1135 that comes when cruising at 55mph in warm weather. I tried swiping sensors, cleaning the solenoids, but it comes back. I guess it is oil pressure related. But I don’t have other typical low oil pressure issues!!
Thread-stealing is a myth. You can't steal electrons, and even if you could, they'd lose potential, head for ground and become useless.
The P1136 is an electrical code, not hydraulic. Check fuse #16 and make sure you didn't pop it. Otherwise, did you maybe dink the IVT connector when doing the work?
The last time I did any meaningful "side work", Obama was still president. Bring the vehicle and a bottle of single-malt Scotch, I'll happily supervise from the comfort of a lawn chair.
Yeah, I see your point. I also found a note from the previous owner in the glove box that recommends using 5w-40 in the summer. My issue is that I am not confident I can get the front cover off and back on without causing more damage haha! Also with age, each connector, bolt, and nut will give a good fight. I did numerous brake jobs, u-joints, part swaps, but never opened engine guts.VStar650CL wrote: ↑Sun Dec 05, 2021 6:38 amYou won't see any low pressure on a gauge when an o-ring pops. The things that are being pressure-deprived by the popped ring are all in or under the front cover; solenoids, phasers, tensioners. Pressure gets measured at the pump outlet just past the filter, and the loss of pressure there will be minimal. When the oil reaches the front cover, the popped ring is simply letting it shoot out sideways into the cover and pan instead of going where it needs to go. The only danger aside from codes is if the bad ring completely disintegrates, then the tensioners can suffer complete pressure loss and allow the timing chains to jump.Soliyou wrote: ↑Sun Dec 05, 2021 3:21 amI am having a similar situation with my 01 qx4. A p1135 that comes when cruising at 55mph in warm weather. I tried swiping sensors, cleaning the solenoids, but it comes back. I guess it is oil pressure related. But I don’t have other typical low oil pressure issues!!
I’ve had some cars develop this milky residue in cold days. I would say if you are not losing coolant and coolant looks green and clean, then I would leave the head gasket alone. Also there is a cheap tester that can be used to detect combustion gases in the coolant. I am sure Vstar knows better though!wesinatl wrote: ↑Sun Dec 05, 2021 7:33 amBtw VStar- i likely do have a bum head gasket. I have been seeing that water sludge for over a couple years. The car needs new head gaskets and new valve cover gaskets, maybe an upper oil pan gaskets and definitely a main seal and likely that front end rebuild. What time can you be here? We can work on the p2647 on my 07 pilot when we are done.
I didn’t remove the cover, but through the sensor holes, I saw a lot of goo on the timing sprockets. I cleaned the grooves on the phasers and the prongs on the sprockets for both sensors to be more active. That seemed to delay the code from coming back for couple of days, but eventually it pops backwesinatl wrote: ↑Sun Dec 05, 2021 6:25 amNo thread stealing! Please follow along as the next piece will interest you. Changed oil and i did remove the drivers side cam cover. There is a lot of nasty in my engine. O rings seemed fine. Scraped the funk from the cover. Also dropped my leaking oil pan and resealed it. Filled her up, and took a test drive. Check codes when i got back and no more 1135. I now have p1136 (plus the knock and o2 sensor).
No, you're quite correct, a gas tester is definitely the way to go. The chemicals won't lie. Even a small amount of blowby in the coolant will cause a detectable color change, so even tiny leaks won't escape it. Vanilla sludge can occur from humidity over a long period, especially if the PCV valve and hoses have been neglected, so it should certainly be verified before throwing head gaskets at it.Soliyou wrote: ↑Sun Dec 05, 2021 1:47 pmI’ve had some cars develop this milky residue in cold days. I would say if you are not losing coolant and coolant looks green and clean, then I would leave the head gasket alone. Also there is a cheap tester that can be used to detect combustion gases in the coolant. I am sure Vstar knows better though!
That's correct, simply because the IVT's won't work after a code gets thrown. The ECM leaves the cams at zero position and runs like a conventional engine without the benefits of Miller-cycling. This won't just affect performance, it will also pollute quite a bit more with the cam phasing disabled, especially nitrous oxides.Soliyou wrote: ↑Thu Dec 09, 2021 1:47 pmCleaning the sprocket and phaser grooves caused it to run longer before the code comes back. Also cold temperatures delay the code.
By the way, contrary to the claim that this code does not affect performance, it actually does. I find the engine to have weak low-end torque and eager to down shift on slight inclines when the engine light is on.
That's a roger, the ehgine relies on the Miller cycle for efficient combustion. Take it away and it can make it look to the ECM like the cat or the downstream sensor has a problem.
