Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Sun Dec 06, 2009 2:13 pm
1. Did you find NisTech's post on how to tell whether it's the sensor or thesolenoid? That's important. The sensors are easy to replace, the solenoidsharder but doable. 2. If you have a code reader, pull the freeze frame, clear the code, wait for itto happen again, repeat. In my case, it was happening at WOT, 1500-2500RPM. Dr, it hurts when I do X. Dr: don''t do that. By avoid WOT throttlein that RPM range, I can keep it away. 3. In my case, I think it's because the truck has 172,000 miles, and the oil pressure is starting to drop a bit (the cams are moved by oil pressure). I switched from 5W30 Castrol GTX to 10W40 Castrol GTX and that has helpeda lot.
4. It doesn't seem to affect driveability at all. I've been living with it for three years and about 60K miles.
5. I'd love to know why, but it seems to be the '01 PFs/QX4 that mostly havethis problem. It seems to be much less common in the later PF/QX4, andmuch less prevalent in other '01 models with the same basic engine.
