I have a Maxima 2001 and recently it started coming up with engine code P1130 swirl solenoid
the symptoms appear only when the car is cold, the rpm is jumping whenever i press the gas pedal
basically what happens when i press the gas pedal is that rpm doesn't pick up and when I press it hard it jumps and falls until the car is hot then I drive normally
while reading on the forums here someone suggested cleaning the vacuum hoses but i'm a noob so i can't really know where that is even after I read the manual
can someone please share their experience?
I have some photos on this link https://imgur.com/a/X02Bt
if you can mark it I would really appreciate it
