wesinatl »
https://forums.nicoclub.com/wesinatl-u274714.html
Sun Aug 11, 2019 4:36 am
ello everyone. 2001 Nissan Pathfinder 3.5 with 215k Miles. It's been mine for most of its life. Oil changes every 5k. Current oil level is good and clean with only 2k miles since last change.
I got a P1135 code a few weeks back. Using my Haynes manual I see that it is a variable valve system problem so I look it up in the index and go to the page to test the IVTC sensors (which RockAuto calls Camshaft sensors and Nissan now calls Crankshaft sensors (this recent change is very confusing)). Anyway I test and decide to replace that bank 2 IVTC sensor - drivers side, front of engine top right, facing the car). Clear codes, code comes back. So then I swap the sensors. clear codes. Code comes back as P1110 which is the same error on bank 1. So now I tap into the FSM which this code is referenced on EC-448 (for those following along in their hymnal). Guess what - These codes don't reference those sensors at all. These codes reference the IVTC system and the following sensors: crankshaft position sensor (POS and REF), camshaft sensor, engine coolant temp and speed sensor.
So my first question of many....if it's not the IVTC sensor why did the code switch banks when I swapped the sensors from one side to the other?
What should my next step be?
I have tested the actual crankshaft sensors, camshaft sensor, both IVTC sensors (or VVT or whatever you want to call them) and they all register as good. Am i going down the wrong path?
I also get a knock sensor code, but I think it might clear if I get rid of the other code. If it wasn't for the CEL I wouldn't know I have a problem. Thanks!
