W O T »
https://forums.nicoclub.com/w-o-t-u75991.html
Mon Apr 27, 2009 11:32 am
I recently threw a scanner on my car (because the original owner was a d!ck and pulled the check engine bulb) and I got a P1140/1145 code. Ok no biggie did the research on here, common problem, replaced both sensors on the front of the motor and the code went away.
Last last week. My car started running TERRIBLE, it has to crank quite a bit extra to start, and I even had it die while coming to a spirited stop or while taking turns Ive even had it die on me. It seems to be idling 150-200rpm lower and the engine sometimes shutters because of this, giving it some gas and raising the rpms to 1000 made the engine run smooth as a kitten...
SO I throw the scanner on it and I get
P1110- Intake Valve Timing Control, LH BankP0335- Crankshaft position sensor
Cleared them, went for a drive (still was hard to start) the car ended up dying somewhere in the drive and thats when the P1110 code came back on , the crankshaft sensor CEL has yet to return (maybe 80miles driving so far this week)
But I cannot drive the car as it is other than to get to and from work, as the car shuts off sometimes randomly, it puts you in a very crappy situation with no power steering!!! Putting it in nuetral and cranking while rolling works though......
I did some searching on here for the last hour but was unable to come to any comclusions as to what the fix would be, what parts could be the culprit, and even a part number, alot of the links were broken or expired.
Any help would be appreciated, as this is kinda dangerous to drive, and I dont have the money to just start shotgunning parts at this rig.
Thanks guys
