VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Wed Apr 17, 2024 12:48 pm
Not likely. Missed teeth on the CKP will sometimes fool the ECM into blaming a wrong component, but it's typically an IVT and not an EVT. Both TPS's, CMP B1, power steering pressure, and one of the APP's are all on the same 5V bus with EVT B1, so it isn't likely to be a global power outage either. Short of scoping the EVT signal, you could try back-probing Yellow and the same wire on the other EVT with the engine running. The voltages should be very nearly identical, if they aren't then you probably have an issue with wiring or pin-fit (or your new sensor is DOA).
