p1078 code
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
[email protected]
p1078 can not clear code
Reason: Revise Title
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
P1078 is the EVT (exhaust cam) sensor for bank1 (passenger side). There are indirect problems that can cause it, but in reality it's almost always a bad sensor. It's located in the back of the passenger side cylinder head.
macgiver
Hey VStar , as Ive been casually going through reading so many sensor problems , like these cam , crank sensor whatever , fully internalized or just bolt-on outside and protrude into the motor . What in your vast knowledge maybe the key to longevity with these components , notwithstanding QC nor poor assembly ?? Like is frequent , quality , full synthetic oil a significant factor ?
I wonder because in virtually all my vehicles , 235k , 285k ,150k miles I've NEVER experienced faults nor codes on them :crazy:
VStar650CL
Technical Expert
The OE parts are pretty darn good, but like any part that combines silicon and inductives, they're very sensitive to ground faults. Couple a dicey ground with a bad location that gets little ventilation, problems are almost guaranteed. The older transverse VQ's are a good example, the rear cam sensors fail a lot more frequently than the front ones just because they're buried at the back of the engine and at the bumf__k end of the engine harness. You can't do anything about the design location, but that's why I'm always harping on people to voltage-drop their ground connections. It's the best 5-second favor you can do your electronics in general. I know you personally take very good care of your battery connections, and if you haven't had trouble with your sensors, I'm sure that's a good part of the reason.
macgiver
Thanks , and your a mind reader :yesnod
VStar650CL
Technical Expert
:) :dblthumb:
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
