P0720 code VSS vehicle speed sensor 00 maxmia
bpomps
so ive been searching for description and fix of this code but cant seem to find much info.
code is P0720 - the code reader i have only states ''transmission''
ive seen a few posts that say the code relates to '' VSS '' vehicle speed sensor.
looking to see who has done this and the OEM part number if possible? if this is a fairly simple job or something a trained mechanic can do?
Edit - been searching and this could also be a grounding issue with the transmission?
thanks
Modified by bpomps at 5:51 PM 4/16/2009
maxhopper
Car: 02 Maxima SE 6spd
Without taking it to a dealership for diagnosis, the only thing you can do is replace the VSS. If that doesn't fix it, then there is a wiring issue.
