P0507 Code
02BlackPathfinder
Car: 2002 Nissan Pathfinder, 1995 Dodge Stealth R/T
at the beginning it started with the code # P0102, so i replaced the Mass Air Flow Sensor and erased the code and everything was just fine. on the third start of the engine the car started revving itself automatically and the check engine light came on for the second time giving me code # P0507 and its telling me that it's the Idle Control System RPM High.
Could somebody please help me out with this?
I just replace the cabin air filter for the first time as well and the Fan Control AMP.
Pwnin O'Brien
After installation of a new MAF sensor, you must complete the Idle Air Volume Learning procedure so the vehicle can idle at the proper speed. The following link will tell you how to complete the procedure. It should apply to your vehicle so you can just complete the process in your driveway.
zer...dures
