p0507 code
grk nickafis
Car: Looking for something fun.
2011 GMC Sierra
My friend has a 2005 altima se-r. It through me a code on my pocket logger. P0507. http://www.obd-codes.com/p0507 ... This website told me a lot but not enough. I have a cold air injen intake and new spark plugs. The clutch is also messed up so please any suggestions as to what is causing this code to pop up..
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
P0507 Idle Control System RPM Higher Than Expected
You probably didn't touch the TB or anything but simple things first, disconnect the battery/ECU for about 20-30 mins to let everything reset. Hook it back up, let it idle for like 10 minutes to learn everything. Take it for a drive and see if the code comes back on. MAF sensor could be pointing the wrong way or there is a vacuum leak causing higher than normal idle.
I'd check those things first.
Edit: I didnt even look at ur link, but I just did and it suggests the same stuff. I found the code on a Google search as well. Has to be that.
