P0446 code
Boston QX
Car: 1997 Inifiniti QX4
So I keep getting this code and I have printed out the diagnosis pages from the FSM.
Just wondering if anyone has had this code and maybe has some info they can add for finding & fixing the problem. Tackling it this weekend.
And if this control valve is no good where can I get one? Can I get it anywhere besides the stealership?
Finny
Car: 2001 QX4
This is generally a generic code. I would look for disconnected or damaged vacuum lines and make sure your gas cap is on tight and in good condition.
If all of those things look okay try a mechanic cause those kinds of codes can be a bear to track down.
If you do find a disconnected vac line or end up replacing the gas cap and the light is still on try resetting it and see if it comes back, those lights don't always go away quickly by them selves.
Boston QX
Thanks. I replaced the gas cap already and had the code cleared.
