P0430 code came up today
4drmadness
Car: 04 g35 infiniti sedan
Hey guys i was just cruising on the freeway and this light came on. i read it and saw that it means TW-Catalyst System, Bank 2. I have kinetix cats and dc headers, do you think that is causing this?
4drmadness
im thinking, i might need to get some o2 foulers.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
The detection logic for a PO420/PO430 will set when the ECM detects a higher the .75% cycling rate that the federal government requires. Basically that means that if the down stream O2 sensors detects an excessive switching from lean to rich, meaning your catalysts are not retaining the oxygen required to complete the chemical reaction to sufficently remove the toxins from your exhaust stream.
Anti foulers significantly diminish the sampling rate of the downstream O2 sensors. While they work your car will be considered a gross polluter and in most states is grounds to fail an annual safety inspect or emissions test (visible removal of a required emission device). Since you have already violated federal laws why not add anti foulers.
I will not participate in another discussion about the pros and cons of defeating emissions components. I'm just giving Vivik some info.
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
yes your exhaust mods are causing the problem. Yes get the spark plug anti foulers and it will go away 4 ever!
4drmadness
thanks for the help Steve, now time to get me some anti foulers
G37 Man
Car: G 37
LMAO
I can just see your whole dash light up with different codes with all the mods that have been done.
4drmadness
hehehe
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
haha
just use the anti foulers
4drmadness
should i just one from ebay
gwoods
you can buy the anti foulers at the auto parts store
4drmadness
cool, thanks
