Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.html
Sun Dec 08, 2013 7:21 am
Yes, there are two downstream sensors. P0420 is for the passenger's side catalytic converter. I forgot to ask, what year Pathfinder do you have?
You will also want to check for air intake leaks (ensure air filter is sealing well and that there are no cracks or holes in the intake tubing by spraying starting fluid or brake cleaner around the intake with the engine idling and listening for an RPM increase - if RPMs rise, you've found a leak) and exhaust leaks.
It may be worth a try to use two 20oz bottles of Chevron Techron Fuel System Cleaner in back-to-back tanks to see if that would help clear the code, too. Change the fuel filter afterwards too, it probably hasn't been done in eons if at all.
