QAM324 »
https://forums.nicoclub.com/qam324-u189921.html
Mon Aug 29, 2011 11:40 am
I have a 2002 QX4. Kept throwing the codes for O2 sensors both sides before and after cat. Happened mostly after fill ups. Found that if I shut off engine before opening the gas cap door it prevented the attendant from unscrewing the cap before shutting off. Also found that using premium for a tank full or 2 speed up the light going off. Also tried using fuel system cleaner the first couple of times it happened. Haven't replaced an O2 since, just keep the door closed until the engines off and the light generally goes off in a couple of days.
