Very dangerous. Nissan engines all use Miller-cycling to avoid needing an EGR Valve, which is great unless a cat melts and disintegrates. If that happens, the engine inhales 2500F debris through the exhaust valves and ends up in the JY. Cat inhalation is 100% fatal. To see if your cats are actually working or not, shoot an IR thermometer at the inlet and outlet end of each cat with the car fully warm, preferably after a drive. The outlet should be significantly warmer than the inlet. If it isn't, that cat is dead and watch out.
If the cats are actually dead, you can't. If they're still working but not working well, spacers on the rear O2's may coax a bit more life out of them.
Three things come to mind.QuestMan wrote: ↑Wed Jul 20, 2022 6:50 amThe second moment which is partially connected to the problem above is misfire. I see that 2, 4 and 6 cylinders have 1-2 misfires in each driving cycle. What may be a reason for this? A month ago I replaced the valve cover near the firewall becouse of oil leack, installed all 6 iridium spark plugs and also installed new three ignition coils from that side. The same job is planning for the front head (valve cover and coils) but I am interested to find the reason of misfire at first. What does it make sense to check? I also found channels from intake to cylinders were yellowish or even a bit brown color, intakes for 2,4 and 6 cylinders looked more dirty. I also checked all pipes to intake, all of them were clean and in normal state, thus there should not be leaks.
Wait, but Nissan vq35DE has an EGR valve.VStar650CL wrote: ↑Wed Jul 20, 2022 9:35 amNissan engines all use Miller-cycling to avoid needing an EGR Valve, which is great unless a cat melts and disintegrates.
In accordance with the odb data, bank 2 has worster metrics then tbank 1. I measured bank 2. The cat is covered with thermal screen, thus I used points near the sensors in the pipe for measurements.VStar650CL wrote: ↑Wed Jul 20, 2022 12:12 pmI know, it's rough without either lifting the car and squirming, or removing the cowl. But unless a cat is already clogged, there's no other good way to check it.
How long does it usually take the way from low efficiency to dead?VStar650CL wrote: ↑Wed Jul 20, 2022 4:49 pmThat one is still working, so you could try spacers on the rear O2's. It won't work forever, but in most cases it will stop the ECM throwing DTC's over a cat that's inefficient but not yet dead.
Done!VStar650CL wrote: ↑Thu Aug 04, 2022 6:12 amCan't get to your pics, the redirect is giving a Fortinet error on all my devices. Try downsizing them under 1M and post them as attachments. Hit the "Full Editor and Preview Button" on this page, then go to the "Attachments" tab underneath the main text-entry box and use the "Add Files" button.
VStar650CL wrote: ↑Thu Aug 04, 2022 7:52 amThat just looks like a crack in the carbon, not a hole in the piston. You always get a layer of carbon built up on any piston crown. In fact, a shiny crown is usually bad news, generally a blown head gasket. That carbon layer is thick, but usually that just means you've been driving like grandma or the cylinder is running rich. Your plug doesn't look super rich, so my diagnosis is your engine needs a serious de-carboning. If the crowns are that thick, I'll hate seeing the backs of your intake valves. They're probably 1/4" thick with carbon deposits.
I recommend a tablespoon of ATF with every air filter change for my regular maintenance customers. That way bigtime carbon never gets a foothold and crushed electrodes are never an issue. It only takes a minute and many of my "not mechanically inclined" customers aren't even aware that I do it for them. It's more critical on DGI engines than EFI, a DGI vehicle with a grandma driver can build meaningful carbon on the intake valves in just 20~25K miles. Carbon doesn't affect the rings, just the crown and valves, so the oil isn't affected by it.schuylkill wrote: ↑Sat Aug 20, 2022 1:51 amIs decarbonization a good idea as a maintenance procedure and if yes at what intervals? Besides the sparkplug fouling are there any other possible problems that may result? Should the oil be changed after doing it?
