VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Fri May 01, 2026 7:10 am
Your '05 G doesn't have O2's in front, it has wideband A/F's centered at 1.5V (lower is rich, higher is lean). They don't "swing" like an HO2S unless the ECM makes them swing, and you'll only see large movements when you're on and off the throttle. In a cruise the swings will be tiny, so your O2S1 readings don't make any sense at all. That 0.295V implies you're running 11.5:1 mixture, which is impossible with a normal STFT. I think your scanner must be giving you artifactual data for the fronts. BTW, your STFT's and LTFT's are all well within the normal range, I doubt you have any issues there.
That all said, the only way to tell anything from your rear O2's is to graph them. Spot voltages tell you nothing. The ECM judges the health of the cat by the timing between swings and the health of the sensor by the minimum and maximum voltages of the swings, so without being able to see the timing you can't tell anything about the cat, and without being able to measure the amplitude you can't tell anything about the sensor.
The bottom line I see here is that since Cataclean helped for awhile, your cat is probably just getting weak in old age. Successive applications will just work for shorter and shorter times until finally it dies and the P0420 won't go away.
