jaworski88 »
https://forums.nicoclub.com/jaworski88-u281387.html
Thu Apr 12, 2018 11:06 pm
Hey, Folks! Thanks for you inputs.
nickelghandi: "... it's nearly impossible for bank 2 to contaminate bank 1..." thanks for the confirmation, because that's what I was thinking too.
Also, I changed the oil right away when I got it, so it is at the right level. However, your comment about the oil made me wonder about something else that I think may be the actual source of my problem. The PO said a shop once told her that it has a valve cover gasket leak, and quoted her $3000 to replace both gaskets. I've confirmed it, it is leaking, but not so much that it's dripping all over my driveway yet. So I think that VCG leak is why I might be getting that P0420 code on bank 1. That is, the oil leaking from the bad VCG may be finding its way into the exhaust on bank 1, and thus fouling it up? Is that possible? If so, then I should replace those gaskets before doing anything else. What do you think?
Thanks again!
