VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Tue Sep 27, 2022 2:17 pm
When occurring by themselves, P0420/P0430 are strictly "dead cat" codes which won't be caused by a bad sensor. The only other thing that can cause them is an exhaust leak in the vicinity of the rear sensor, but we see that very infrequently. In this case, your cat is progressively getting weaker which is why the ECM is flagging it more frequently. There's nothing wrong with going aftermarket on the cat to keep the cost down, but don't go bargain basement, stick with a reputable brand like Bosal, AP/Eastern, Walker, Davico, etc. Pretty much anything you find in RockAuto will be reputable, China-cheap is what you want to avoid. The job itself isn't rocket science but it isn't easy either. A good general repair shop should have no issues with it, but most will quote additional labor time to account for rust and corrosion on an older vehicle. In this case, Motor quotes 1.1 hours for either side but most places will probably upcharge to 1.5~2.0.
