I'm at a loss on where to go next, if anyone can throw in any suggestions I would really appreciate it. The 2003 z I bought came with a P0345 cel code, camshaft position sensor bank 2. I started with first replacing the sensor, while also replacing the bank 1 sensor and crank position sensor, with oem hitachi, that didn't help. So I checked the power and ground to the connector, checked continuity through the wires to the ecu, couldn't find any issues. I just went ahead and decided to replace the timing chains, found the dowel pin for the camshaft and the sprocket was all mangled up so I figured that was the issue, replaced those pieces but the car is still having the same issue. Won't rev up past 3k rpms, and the cel, slip, vdc lights all come on quickly after trying to drive. Tried throttle position re learn multiple time. Don't know what to do next and I dont wanna give up. Thanks for any help.
