I lend my car to someone for 2 weeks, got it back and it ran like s***. Now I thought I was imagining things but got it dyno tuned and it dynoed only at 166hp.
I checked for error codes and I had a P0325, bad knock sensor. They typically last only 7 years so I figured it was time to replace it. To not waste money on OEM gaskets I also installed NWP phenolic intake spacers, since I was taking the Upper and Lower Intake manifold off anyways.
Put everything back together.... the code is still there! So I figured out it might be the wire. I tugged a little on it and BAM i had it in my hand. Ordered a new one already but I took what was left of it and connected some resistors and made a knock sensor simulator. Went to autozone, cleared the code and as soon I started the car again the code was back!!!!!
What else could it be? The wiring from the ECU to the KS? Can I check the female connectors at the knock sensor -> ECU harness for some current with a multi-meter?
This is the highly condensed version of the problem, the entire process took me 2 weeks now but I'm getting really frustrated and maybe you guys can help me out. I'm not gonna get my car re-tuned until I know for a FACT that the car computer isn't pulling and timing... It's thievery! I should file a report for being robbed of the most precious and valuable horsepower!
EDIT:
I checked the Voltage at the Female end of Connector F121. KS Harness -> ECU and it read 340V ?!?!
Modified by McSteve at 4:37 PM 4/12/2010
