Willy thank you for your reply. the reason I asked because my old spark plug in cylinder#2 seems very loose, it could be not fully tightened from last spark plugs change or it got loose after few years engine operated.willy0505 wrote:If you mean the coil pack, then no, I did not replace that. However, after reading on lots of these forums about the P0302, it could be the coil pack or the spark plug. I did not see a 'seal' though....
W
