Sounds like at the minimum you may have a valve cover issue that you need to take care of (the oil).jhonatansc wrote:i have an 03 sedan. the computer read misfire on cylinder 2. the electrode was broke in the spark plug. i changed the spark plug and checked the compression and its 120. the boot was full of oil. i cleaned the boot.
also, i checked the coil and spark plug and is sparking. after that still reading misfire on cylinder 2. can a fuel problem cause this code?
yes it does.SVTCOBRA wrote:The valve covers are known to have bad seals in the spark plug chamber.Does it feel like it's mis-firing?
