silentdub »
https://forums.nicoclub.com/silentdub-u297386.html
Mon Nov 04, 2024 9:12 am
09 370Z 100K Miles
Getting a P0300, after reviewing the data stream, everything seems normal, no out of range readings. We can reproduce the issue and on the misfire counter, we can reproduce it only at 50% throttle.
We are getting misfires on bank 1 only, bank 2 is fine. When at idle, no misfires, when at WOT, no misfires. When at 50% throttle, we get the stumble and the misfires are physically noticed and counted on the data logger.
There are no codes other than the P0300, no MAF or TB Codes.
I am leaning toward an issue with bank 1 TB but that would just be a guess.
The one thing that is troubling me is a ‘long crank’ when starting especially when cold but the car cranks longer that it should before starting. I have found this issue with ?Nissans to be an issue with the crank sensor in the past but combined with the misfires as noted above, that doesn’t make sense.
Thoughts?
