bdavis007 wrote:My 06 M45 with 93k on it recently threw an O2 Sensor Code after some disscussion here I cleaned the MAF and cleared the code.....It wored and I didnt have any issues until this evening.....I got home and it idled very rough alomost to the point of dying out....then I took it back out and th CEL come on and I could barley acclerate.......The car starts fine, but after about 2 minutes the rough idle starts and the CEL comes on....
i have reserched the code and it appears as though it is plugs or coils?
There are a lot of walkthroughs on the M35, but not much on this motor....is this a DIY situation? I have replaced the pulley and the wheel bearing etc....
Might you know if your o2 sensor code is back along with the P0300?
Also, pretty funky that it would idle badly enough to almost die if it starts just fine. Is this (
2 minutes) how long long it usually takes your car to come to operating temperature?
I will look into this a little further tomorrow, but yes, if it is the plugs and coils, it would not be a very difficult DIY, especially if you have done bearing work. Small issue with clearance to insert a socket extension long enough for the rear cylinder spark plugs, yet short enough to clear the engine bay walls, but nothing an extensive toolbox can't fix.
