P0300, P0325, P0330 Error codes...need help...
Reaper007
Car: 99 Infiniti Q45t
Hi everyone I need some of your expertise. I own a 99 Q45t, Ive had it for a year. Recently I got a check engine light and the codes that popped up were P0300 P0325 and P0330. My questions are the following:
Is it possible that the misfire caused the knock senors to give a bad reading, or made them malfunction?
Or are the bad knock sensors the cause of the P0300 misfire code?
Which gaskets will I need for the job?
Does anyone have a service manual or guide that may help me with this repair?
I Appreciate you takin the time to read this and for any help you can offer.
Thank you,Jon
Q45tech
The FSM is *pdf download. KS code come from a failed resistance test during startup.
