Hi Fernando, and welcome to Nico!
The best thing to do is use the search button on the right of your screen (should be flashing)
There is a good chance that the problem you are having has been experienced by another member.
A quick search found me this...
Chuck Tribolet wrote:P0174 is US drivers side running lean. FSM says these causes for P0174:
Intake air leaks
Heated O2 Sensor 1
Injector
Exhaust gas leaks
Incorrect fuel pressure
lack of fuel
mass air flow sensor
Incorrect PCV hose connection
Not a word about the cat. It does have about eight pages of how to figure out WHICH of the above it is.
Try some of those things, and see how you go.
