ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu Oct 28, 2010 11:49 am
Rich condition is built in to ECM (CPU) but more a programmable controller than a processing unit and takes into account the "Stoichiometric or ideal condition of fuel to air for proper combustion. This ideal ratio is 14.6 to 1, 14.6:1 with air providing oxygen and fuel being gasoline. By volume there is 14.6 x more air than fuel and if the amount of air drops or the amount of fuel increases the ratio changes.
Too lean results in a higher over all temperature, destroying plugs, valves, springs, and combustion chambers
Too rich is opposite but bad also in that the condition fouls plugs, creates carbon deposits and cools combustion and destroys MPG.
Both conditions are expensive and bad for the engine.
The causes related in previous posts but can be created by the fuel your using. If you do not want to change octane ratings at least change where you are getting fuel, just an experiment. The vehicle has little history with you so you are going to have to experiment.
A new throttle body is assumed to be good, remove the conduits feeding it and look. If your system is by wire instead of springs, cable it should be easier to view. If you are not good with tools take pictures.
You must correct the condition that creates a coded DTC, trouble. A rich condition is the use of excess fuel by using too much fuel or starving air which contains the O2 levels. How long has this car be running rich...if you do not know take a look at the end of the tail pipe. Is it black with soot deposits. If so the rich mixture has worked through the engine to the catalytic converter, through that and to the end, but along the way both O2 sensors before and after the converter are covered with carbon and likely they are slow to change your mixture ratio while you drive.
At this point the engine may not be carbon prone but the O2 sensors have been covered with carbon and the overall picture of the exhaust is too much fuel deposits so the ratio is out and CPU are dumb enough to interpret that as too rich. All because the rich condition covered the O2 sensors.
The other choice if you do not want to pursue this problem is to pay someone to fix it.
But whether you do it or a paid professional you both must investigate the causes and now the effects.
Check the tail pipe
If clean then pull the O2 sensors.
Try cleaning the end or replace
Look in the mouth of the throttle body, carbon any where if so clean
Remember that the ECU gets input from the sensors, check the sensors, not very often the ECU is bad...but it happens...check the obvious...the easiest then clue us in.
