ok heres what u should do... starting from the cheapest.will1300 wrote:i saw ur comments and wodering what sesor you took out I have a 2001 pathfinder and it gets a p0171 is that the same u had Thanks Will
first...check for any leaking hoses around your intake and throttle body. check the throttle body gasket.(if your getting bad gas mileage that could mean your sensor is bad)
third... make sure u check your maf sensor for any damage, or dirt and test it to see if its working properly. some symtoms of a bad maf are...hesitation. rough idle or engine is rough when cold. driving on the highway you will notice major lack of power and changes in speed....try using electronic cleaner and clean it out thouroughly...if defected u can go out and get a 01 nissan maxima maf sensor for like 120 bucks and it can be used for the 01 pathfinder.
I went through the same thing u went through and i did what i just posted and now my pathfinder is driving butter smooth and no ses lights for the past 2 months. the light goes out on its own
good luck
